Old 09-03-2001, 09:14 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Jack21, The alignment specs are:
Caster 3.75 degree + or - .5 degree
Camber 3/8 degree + or - 1/8 degree
Toe-in .03 to .06 (1/32 in. to 2/32 in.)
I've never had a problem with the upper arm moving. The arms I use normally have a knurling on the cross shaft where the T-bolts go to lock the arm in place. I would think that the nuts probably weren't tight enough.
Don
