My body is sitting right on the uprights, there is an extra small fiberglass pad between the body and the uprights. Don't have a splitter but I would advise you to either use the B&B aluminum nose peices or at least bend up some aluminum between the bottom of the nose opening and the bottom of the radiator. You can bend up the sides and attach to the inner frame rails.This dropped my coolant temp by 10-15 degrees.
