Old 01-14-2008, 09:08 AM
ItBites's Avatar
ItBites ItBites is offline
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
You did not indicate your compression ratio, so some of the necessary info is missing. But since you left the CR out, I am guessing it is not 12:1...
My opinion: This is pretty long duration for this small motor (Over 525 ci will effectively "shorten" duration), especially without high CR and with the small separation at 108. I usually associate 108 separation and over 260 deg duration with high rpm engines. I think it will be a headache to drive and will not have good street manners.
If you want good street manners with low CR for running pump gas, I would keep duration to 240 deg max and make the separation angle 112 or 114. Do whatever lift you want as long as the springs are OK.
Only my opinion.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
