  #218 (permalink)
Old 01-14-2008, 04:36 PM
fasterpatrick's Avatar
fasterpatrick fasterpatrick is offline
Cobra Make, Engine: scratch build self design 4.6l DOHC
Default This may be out of sequence
Well thank all of you for your input. Here is what I came up with. I have eight points that will be glassed into the body for hidden mounts,plus the three points around the door sill (anti intrusion pins through the body) and the bumper mounts.
Now I can mix up some goo and fix the pads to the body and continue with the panel construction portion of this build; Patrick
