  #220 (permalink)
Old 01-17-2008, 06:59 AM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
Originally Posted by fasterpatrick
Well thank all of you for your input. Here is what I came up with. I have eight points that will be glassed into the body for hidden mounts,plus the three points around the door sill (anti intrusion pins through the body) and the bumper mounts.
Now I can mix up some goo and fix the pads to the body and continue with the panel construction portion of this build; Patrick
I think you'll find on the first hot sunny day this car sits out and the body gets hot you'll see the round imprints where you laminated the support disc. On the lower sides i don't think it's a problem but on top it's gonna sag..
Mike
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
