Old 01-17-2008, 02:32 PM
rdc767 rdc767 is offline
Cobra Make, Engine: A&C
wakeen19
Congratulation's!!!
Post some pics of your car.
Explorer rear disc are 11" with a emergency brake combined. I found a 1995 at pull a part. You need to get the rear disc bracket from the junk yard. You need to pull the axles and loosen the brackets to get them off. Leave the disc's and calipers behind. The bracket bolts up to the rear end. I got the calipers and rotors from
http://www.rockauto.com/
The emergency cables work but get 2 of the shorter cables I can't remember which side is shorter.
You'll need a spacer for the bracket. The same company that makes the axle sells them. 9inchfactory store.
I think I have less then 200 dollars in rear brakes.
