Old 01-17-2008, 03:56 PM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
Cobra Make, Engine: Daytona Coupe
While you are pumping up the oiling system it is a good idea to pull the valve covers and look and see if the valve train is getting oil. The FE with the oil going up the rocker arm stud is really easy to get wrong...
Also high detergent (diesel) oils are not the best for break in. They tend to clean the cams of cam lube. After break in Rotella should work great.
Evolve Lubricants
https://evolvelube.com/
Cubic Performance
