Old 01-18-2008, 04:15 PM
jacb's Avatar
jacb jacb is offline
Send a message via Skype™ to jacb
Originally Posted by ekrupa2
I'll second the suggestion for a QuickTime bellhousing. Top notch all the way.
I asked "Do you make an SFI approved bellhousing to fit between my Ford 351W (Dart iron block) and a TKO 600 (fitted with a short input shaft kit) without using a spacer? I hope to use an external slave cylinder and I plan to use a McLeod RST 6913-07C clutch kit - My flywheel is a 157 tooth item"
Just in ...... From Kim at QuickTime
RM-6063. Retail is $401.70.
We currently have non-SFI certified models in stock. We are switching this model to SFI. We are running them right now. These will be available in less than 2 weeks.
Thank you,
Kim Robinson
Vice President Sales/Marketing
QuickTime Inc.
641.673.4468
