hi simon,
i can seee it is a RAM, but unfortunately I cannot help you with the engine question.
Look out for the lenght of your rear axle arms!
I guesss they are not cut to gie room for wider rims.
I cut mine up to the point that when lifting them all the way up (springs compressed) they hit the chassis.
To give even more room I cut the aluminum wheel bearing housings about 15 mm at the top end.
Are you aware of that?
In addition I may check my old notes to find the correct measurements how much i cut the parts.
I sold the car, otherwise I could just gonin the garage. But I remember at least 60 mm on each side to give room for 9.5" wheels.
I you are able to put the body on: you want 200 mm (8") from the edge of the fender to the wheel mounting flange.
Dominik
