This is my air-
oil seperator/ PCV/catch can. It's actually a Stefs puke can, filled with stainless steel mesh, and with the PCV in the top. The inlet is in the center, and comes from the left side valve cover. The right valve cover is connected to the air cleaner and draws fresh filtered air into the engine. There is also a drain in the bottom of the can for any liquid
oil that may have traveled up the hose. So far, the engine seems to get only vapor, I haven't detected any
oil at the PCV. This is a small block, but I don't see why it wouldn't work on any carbed engine. John
