  #26 (permalink)
Old 01-24-2008, 09:36 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Following up on the removal of inner springs for break-in with solid lifters, once the inner springs are removed how long, (time, miles?) and or what type of RPM range would be recommended before returning the inner springs.
I removed my inner springs for initial start up and ran my FE for around forty minutes with cam lube and EOS added before putting it into storage with the spring pressure relieved from the rocker arms and the inners still out of the engine.
I am using a reasonably mild cam, comp cams 282S.
