Actually everyone that uses a Lakewood with the backing plate has this problem simply because the backing plate of the Lakewood is much thicker than the stock backing plate from Ford. All the Ford starters are designed to work with the standard Ford belhousing/backing plate. It's not that big a deal to remove the face plate from the starter and have it machined. Much cheaper and easier than replacing a flywheel.
ERA #509
2003 Z06
