Old 01-25-2008, 01:31 PM
GlynMeek's Avatar
GlynMeek GlynMeek is offline
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Default Valve Cover Bolts
I have a stroker 347/302 engine with about 700 miles on it at the moment. Still 'running in' gradually, and (touch wood), most things seem to be OK.
I was just checking all over bolt tightness the other day and found that the middle (top and bottom) bolts holding the valve covers on had become loose. In fact, one was so loose it had come out altogether. Checking all the other valve cover bolts, I found that all of them needed some degree of tightening or another. I tightened them as much as I dared (NOT wanting to strip threads!) and thought I had cured the problem. Drove the car for a couple of days and checked again, and the damn things had loosened up somewhat again.
1) Is there a specific torque setting I need for valve cover bolts, and if so, anyone have any idea what it should be?
2) Should I use loctite on these, and if so, red or blue?
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
