Old 01-25-2008, 12:59 PM
J Persons J Persons is offline
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
The bolts are 1/4-20, and there is a specific torque for them, but if you are using aftermarket valve covers I don't think I would want tighten them that much. Most aftermarket valve covers have a much thinner flange than the factory covers do and you could crack the flange, especially if using a thick gasket with lots of compressibility. I would just install them snug and use a drop of blue locktite on the threads. I use Allen head bolts and tighten them with a "T" "wrench. Also, make sure the bolts don't bottom out in the head.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
