Old 01-26-2008, 07:34 AM
fourbar83 fourbar83 is offline
It WILL break down over time......three or four seasons of racing and then start cloging fuel sysetems quick and all the time. If you do use it replace every other year to be safe. A trick used in dirt racing is to use wiffle balls (the plastic balls with holes in them) or a cheaper and easier alternative is to take 1 1/2" PVS pipe and drill 3/4" holes in the sides so that fuel can move around but control slosh with out breaking down like foam.
Hope this helps.
