Old 01-30-2008, 08:51 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Use a balanced thermostat. It fails open. and be sure the little hole drilled on the edge is at the top when you install it. Be sure to purge all the air out of the system too. You can also get a lower temperature fan switch for the bottom of the radiator, but it's no fun to install...
