Old 09-06-2001, 02:52 PM
ERA#569 ERA#569 is offline
Hello Gary, I have installed / removed my engine 2 times(before I started it !). The best I think is to Remove the Trans & Bell housing out from the interior side(with back of engine supported). Then with the Alternator, etc. off you can pull the engine forward a couple of inches and pull STRAIGHT up !! I was very surprised how easy it go's in and out ! Make sure you have help to hold the engine steady and take your time ! Make sure you have alot of blankets or towels linning the engine opening. Make sure you plug the fuel supply line if your gas tank fuel level is higher than the end. Disconect the battery terminals for good measure.
Good Luck, Scott
