Thread: website issues?
  #43 (permalink)
Old 02-01-2008, 02:21 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Brent,
Thanks and I am sorry for all the complaints. I just don't understand why it worked so fast and no problems of any kind for the first couple of days and now all of a sudden I seem to hit every type of possible problem. And as I have stated, the first problem I had was the day you put the Nav Bar back in. There is no set circumstances such as just changing forums, posting, or anything at all to go on. Before the Nav Bar mine would work like it used to except faster. I would submit a post and the green bars would just zip across and the post was in. Now even when it works then first green bar comes on, it pauses for a second, and than when it works then rest will start, but sometimes they get almost all the way across and then go back and start over and put the post in. Other times as I mentioned it is like the whole page does a refresh and dumps me for just a split second, comes back up and puts the post in or takes me to the Forum I want to go to. That pause at the first green bar is what I can't get. It never did that before and I can now tell as soon as it pauses if I am going to have to disconnect or if it is going to finally put the post in. Then about once out of every so many posts it will just zip across like it used to.
If you want to call me and come into my computer on the remote like Ron did to see if it will happen I would be happy to work with you at any time. Ron made a couple of test posts and it just paused for a second and went in and then the site went off line.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
