You can block the
oil flow to the heads by using a restrictor on the deck of the block, since the heads don't get
oil through the pushrods. Bushing the lifter valley would only reduce the amount of drain back. You want the
oil to drain back as quickly as possible, so those returns need to be kept open and the drainback holes in the heads need to be open as well.
