Doug will advise, I'm sure, but it sounds like a very small adjustment in the hydraulic throw out bearing distance should cure the problem. On mine, it's a matter of turning the bearing slightly on a threaded sleeve. (A wire tie is used to try and prevent the bearing from turning on the sleeve). Problem is you have to pull the trans to get at it. (Doug may know of some trick to adjust it through the bell housing throw out arm hole...)
Jim
