  #26 (permalink)
Old 02-02-2008, 09:45 AM
patrickt patrickt is offline
Originally Posted by RICK LAKE View Post
The info you have for oil pressure doesn't include the Nascar motor. IMO if you want to run a heavy bottom end motor on 10-15 psi of oil thats your choise.
The closest I can get in my old manuals to the Nascar engine is the R Code Specs below, 505HP, 13 to 1 Compression. Here it is (but I will concede that there is always the possibility that someone puts the wrong parts in). Note the oil pressure specs in the upper right hand corner.
Do you know which cycle is hardest on a motor?
Uhh, premenstrual?
