02-02-2008, 01:16 PM
AZ
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
If you tried a 0 - 60 mph run on a normal road with, sea level, 12 inch rollout on decent tires and to include a good 1 to 2 shift you'd probably see around high 3s to low 4s. You'd probably knock off a half second at the drag strip if the track was prepped. If you had no shift before 60 mph you could knock off another .2 to .3 seconds.
