  #30 (permalink)
Old 02-03-2008, 08:49 PM
CWizard CWizard is offline
Cobra Make, Engine: SPF, 418 Stroker
Originally Posted by ou812545 View Post
After reading through the threads is appear that the Olthoff Engine mounts seem to be the best solution for the problem. The only concern I have is how easy of a swap is it and will it increase the engine height?
Dan
It's a pretty easy swap. You'll have to modify and reuse one part of the existing mount, which is a 10 minute job with a hacksaw. The Olthoff mounts come with instructions on how to do this. Also, in my case (also a 418W) the engine height was not changed appreciably. But be sure to check for clearance at the air cleaner and coolant tank before you button down the hood. The only undesirable part of these poly mounts is that I now have to loosen them and swing them back a bit in order to remove the oil pan. With the original $16 made in India mounts, there was no interference with the pan. For me, it's a small inconvenience relative to the benefits of the poly mounts. Good luck.
