Old 02-04-2008, 12:46 PM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
Doug,
It has been a couple of years since I had Custom Alignment do mine.Everything was way out of wack. The inside of my right front tire was wore out, and the outside was like new. The car rides and handles a 100 times better!
When they start on these cars, it gets up there quick. I believe replacing the springs alone was around $400. The four wheel alignment was the cheap part.
I had to take my car back to Custom once I put the Michelin tires on it. I had a local tire shop install and balance them. I ended up with a major front end vibration. Took them back and they rebalanced them again. Same problem. Took them off and took them to Custom, and still the same problem. So I took the car in with the tires on it and had them balanced on the car. Now it's good. I didn't have this problem with my Good Years??????
Scott
