Originally Posted by RodKnock
OK, it's starting to become a little clearer.
Sal, what type of intake do you run? So the intake and valve covers determine which method one uses (i.e., closed valve covers and puke tank versus breather caps and PCV)? I actually have the Shelby intake, not the Edelbrock RPM. I'm now wondering if they have a breather tube in the front of the intake and a vent in the rear.
I am running the Blue Thunder intake which is a copy of the original Medium Riser. It has a fill tube in the front with a breather cap on it. When you buy it new, it also comes with a plug for those who don't want to use the fill tube.
If you use the fill tube, you can't have a PCV. If you use the plug, you can have a PCV. You can run a PCV two ways... either coming off the valve cover and going to the intake/carb (to be injested into the engine) or off the back of the intake and to the intake/carb.
Sal Mennella
