Thread: Canton oil pam
Old 09-08-2001, 02:43 PM
RobMcQuarie RobMcQuarie is offline
Default Front Sump Pan
Pat,
I kind of wondered why you were asking about a rear sump, that's why I thought I'd describe it for you.
The pan you want is a 15-680, which is the front sump 351W road race "T" pan. The std "T" pan w/o trap door baffles is 15-660, but for the $50 extra, I recommend the road race version. Pick-up tube is 15-661. The front sump also fits with the girdle, with the same "fitting" of the crank scraper I wrote about above. You do have to bend the dip stick a bit to clear the MCG, so make sure you fit it BEFORE you put the pan on. I may have one of the 15-680's in stock if you are interested. Check the width between your frame rails. The pan is 13-1/2" wide, which just fits on most Cobra's. A narrower "T" sump can be made, as one kit out there is too narrow-don't remember which one. We just put a 408W with one of these pans in a Superformance, and it is snug.
Rob
