Old 02-12-2008, 11:26 AM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
I bought the ACIII wheels and the center "threaded" portion is a little weird: it is loose in the wheel until you tighten it up with the spinner. I ended up making some spacers to fit behind it because the piece would drop too far into the wheel for me to start the spinner! When I called, they suggested some silicone to help hold it to the wheel while you start the spinner. Other than that, the spinner itself is nice and heavy duty. The lug nut cap matches well with the rest of the wheel.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
