Mike
Do you think there's a reason that control arms are Straight from the upper chassis pick up point to the upright????
And bump steer needs to be .015"thousands of an inch per inch of travel...... from ride height in a bump or droop situation.
And not on a piece of wood...... not flat and accurate......
Don't mean to bust your bubble.... but if you are going to do what you are doing .....get it accurate or you may hurt yourself.
The bump steer can be controlled by rotating the upright...... and your upper control arm would have me concerned if you have any power applied to the rear wheels and they have any grip.......
Just some thoughts....
Morris
Morris
