Old 02-13-2008, 06:31 PM
patrickt patrickt is offline
Originally Posted by CJ428CJ View Post
As I recall there are 2 case sizes and the gears between the two case sizes will not interchange. I could be wrong, but I think the 2.88 and 3.08 gears fit one case size and all the others fit a different case size.
I recall that 3.73 and numerically lower gears all fit the same case and you only run in to a problem when you're crossing the 3.73 threshold (like going from 3.54 to 3.92). But I'm not 100% positive, so check before you buy.
