"I thought you were asking about swapping transmissions. I would - I did and the result is worth it!"
so cobra 29, what difference could you tell besides the gear changes?
well dwight, i had a 3550 and was going to a t5 to save 30#'s, but am now getting cold feet. i'm building a motor that should be close to 500 lbs tq at least and the jbl has lots of rear tire 335/35/17 and lots of weight transfer so i don't think the rear tires breaking loose is going to play into this too much. you're running a 5.0 with the 600? hmmm, i don't think that one will break.
i suppose autocross would be hard on the tranny's using one gear with the loading and unloading. anyway,the debate goes on.
thanks for the input.
