Old 09-10-2001, 10:37 AM
dwisdom dwisdom is offline
Default Part numbers
Here are the part numbers for the Rocker Arms and Pushrods (although I have gone with different pushrods since purchasing the Cranes)....
Rockers - CRN-34772-16
Pushrods - CRN-34645-16
The second set of pushrods were purchased from On Track Performance, 9.360 to bottom of cup measurement.
George, after reading your URL "how-to" on valve adjustments, it appears that I have done this right... one of the steps says, Turn the engine over until the Intake completely opens and almost closes? Does this mean, the intake starts to close or is almost closed after opening completely then continuing to turn over until it is almost closed? Don't mean to be so technical, this adjustment has just been more of a headache than I anticipated.
Lastly - there was also a note about the Edelbrock Performer RPM 7105... I have this one and do see a possible clearance issue in the bores. I have checked the pushrods for scuffing marks and do not see any present - hmmm.
Thanks for the support.
One more thing for the rest of you - I did assume that some had bad experiences with and others didn't. The opinions are much appreciated though - thanks again.
Don
