Old 02-17-2008, 10:37 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Its a fairly straight forward process. You have to heat the main inlet feed at the bottom of the tank to break the solder joint there and heat the bracket flange on the backside of the mounting bracket. Once the solder starts to flow it all comes loose pretty easily. Clean it. flip it and resolder. I had to fab a spacer to keep the tank from banging into the distributor.
Before rotation on bracket
spacer
