Old 02-22-2008, 04:08 AM
undy's Avatar
undy undy is offline
Don't worry about it..
Everything in the differential/axle tubes is splash lubricated (or a sealed bearing). Small amounts of carbon flaking are just going to fall, sink in the rear lube and lay there for all eternity.. (or till you change your oil .. if .. they even washed down to the center section) Even if the carbon got in a bearing/gear it would disintegrate and wash out with the oil.. Weld those puppies and keep on gettin' it!
Dave
Too many toys?? never!
