Old 02-22-2008, 05:31 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Wetdog,
What is the problem with the pick-up? The sender /pickup used is a typical GM (Vega?) unit but I can not tell you what year or model. I have gotten some old tanks that had sat around for a while and had collected some moisture in the tanks causing the nylon bag on the end of the pick up to collect rust particles. Another way to go is VDO's adjustable sender, bolts right in and you can adjust them to actually fit the tank perfectly but of course you say the pick up is the problem not the sender.
Adding a different pick up is totally do-able, especially with your talents. May I suggest if you do, do not put the bung in the very bottom of the tank but the front middle of the tank at the bottom with an AR type aircraft fitting.** (You are accustomed to those -no.)? Then you can use braided steel fuel lines to the motor, (3/8's is plenty big enough for a stroker 351) and really be cool and be a perfectionist too! (Don't forget to make provisions for a filter for the pick up on the inside!)
This is really cool, like building another Cobra only by proxy!
DV
** ON the inside-extend the pickup on a semi-flexible tube, extend it to about the midle of the tank, just before the tank takes the slope up and rearward. This way it will always be in fuel. If you really want to be on top of it, use a hollow weight on the very end of the tube (spark proof of course), this will allow the tube to swing in the tank under hard cornering, never coming out of fuel in a auto cross type event.
