Old 02-22-2008, 12:01 PM
1966plus's Avatar
1966plus 1966plus is offline
Default One step closer
well finally we have got the engine, transaxle and headers into the back of an MDA series II chassis (well OK it is an engineering frame of one - but the one they use for testing new configurations and parts)
Overview
Headers Right Rear view
Headers from the front The spacers you can see are to simulate the adaptor plate that is away being machined
The Big Guns
After a change of plans (brought about by both myself and MDA not realising the 930 clutch uses a pull system rather than a push one ) there will be a pull arrangement engineered for the clutch which will stop be using a Hydraulic Release Bearing (to keep things neat)
The KEP clutch assembled
Small FE Flywheel
Craig
www.miragemk2.com
