Old 02-23-2008, 09:04 PM
Silverback51's Avatar
Silverback51 Silverback51 is offline
Well after spending hundreds of dollars replacing the distributor, coil, plug wires, plugs, cap, rotor, tach adapter, and the MSD 6AL box, it turned out the be a $32.00 voltage regulator.
Today I rewired the entire system again. Still missed, so then I removed the fan belt and started it up. No miss. Replaced the alternator and then it missed again. Replaced the voltage regulator and magic happened. It ran fine.
I cannot believe how well it runs now. The new carbs are awsome. In second gear at 2500 RPM's I stepped into it at about half throttle. Broke the tires loose, and put a big **** eating grin on my face.
I'm in love again.
