Jerry, the EMU is the correct application and can be used with a 2 cylinder all the way up to a 16 cylinder application! I can run staged Injection, throttle body injection, phase-sequential injection, full sequential injection, rotary injection. Most applications will use the phase-sequential firing option. This firing scenario
pairs cylinders that share their TDC's to the same injector channels. As such, one injector channel fires two injectors: one on compression and the other on exhaust. Each injector channel will fire once per revolution, so each cylinder will see a shot of fuel on both the exhaust and compression stroke. In an 8 cylinder application, each injector channel has it's own staged injector channel. 16 low impedance injectors could be used with this firing scenario. Jerry, don't get me started on the features of this thing. Some of the features -- I actually know what they are
