Old 02-24-2008, 03:17 PM
diegokid diegokid is offline
Cobra Make, Engine: Unique
Default dial indicator
I used a dial indicator set on the top of the block. Turned crank until upward movement stopped set my zero. Continued turning crank until max indication of 3.625. I even considered a bad rod or bearing and checked an oppisite cylinder, same reading. I then checked my indicator with known tools for this, it checked good.
