Originally Posted by Tim Brewer
Then, if that's not working, I would remove a valve cover, start the engine and look for oil pumping out.
START the engine? ....NOOOOOOOOOOOOOOOOOOOOOOOOOOO
Remove the coil wire and crank it over to see if
oil is circulating. Does the pressure increase on the new gauge installed?
NEVER start an engine when the
oil presuure gauge says ZERO.
