Here are some questions which might help 767 Jockey as well as myself:
1. Do your plugs burn properly( tanish brown)?
2. Do you get a spitting / sneeze out of your carbs once an while (somepeople say this is a common trait of Webers)?
3. Does the temperature change the characterisics of the Webers?
4. Does your fuel pressure fluxuate when you first start your motor vs when the motor warms up?
5. Is there a specific cam seletion that should be installed to run Webers?
6. Those that have Webers please indicate what system you previously had before installing the Webers i.e dual 4 barrels.
7. What did notice when you switched to the webers performance wise?
