Originally Posted by Randy Rosenberg
I just installed the same kit last weekend, however I installed the phenolic under the heat shield, not on top of it. My theory is that I want the heat shield not to absorb heat from the manifold and radiate it to the float bowls.
I tried that but my accellerator pump arms would hit the tin. So I switched it. If it works for you that's probably prefered.
Chuck
