Old 02-26-2008, 10:37 PM
767Jockey's Avatar
767Jockey 767Jockey is online now
Default TKO 600 shifter location question
I have a Contemporary Cobra that I'm installing a FE with a TKO 600. It's my first Tremec, and I have what I hope is a simple question. I have a bent forward original type shifter handle, and I'd like it to come out of the tunnel in as original a location as possible.
The transmission was shipped to me with the shifter plate ad assembly mounted on the aft most shifter mount point on the transmission case. It appears that the shifter can be mounted on this point in two different positions, one with the shifter handle in the rear most position of the aft shifter mount point, and another mounting option with the shifter plate mounted again on the rear most mounting point on the transmission case, but with the plate rotated 180 degrees, with the shifter handle now in the front position of the rear most mounting point. Which position will give me the original shifter location with the bent forward handle in a 427 S/C type car?
