Old 02-26-2008, 11:17 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Default Weber hood clearance height?
Does anyone have an assembled height, similar to Edelbrock's A/B method, of assembled Webers measured form the front and rear block surfaces to the top of the air horns? As a general rule, are they normally higher, lower or the same as an average dual plane with a turkey pan and single 4bbl?
My choices will come down to a Edelbrock Performer RPM with a Holley double pumper, S&H air cleaner and a turkey pan, or a set of Webers with air horns. I'm not even sure the Webers will fit under the hood, and I can't find assembled Weber heights anywhere.
Any help is appreciated. Thank you.
