Here is a pic of cam going in. Just needed to jack up the engine a bit.
Pic of piston with clay on top. Measured it with the head gasket on and the proper length set up on the pushrod checker. Used only the inner spring. Good clearance, but we had to be safe since we both milled the heads AND went to more valve lift on the cam.
