Old 02-27-2008, 05:01 PM
RedBarchetta RedBarchetta is offline
Banned
Originally Posted by rtstrack View Post
The car cables have small loops that went on a 5/16th screw-in top post battery. I couldn't find a replacement battery with a threaded post, so i got a standard top post battery and bought connectors (the typical ends to a battery cable) that would slide on the post and in turn i could thread the looped cables onto one of the screws on the connector. I doubt this helps much, but I thought I'd try.
This alone helps A LOT! You may not be getting enough "juice" (i.e. cold cranking amps) through that connector. Swap out your battery cables for ones that fit the battery (or exchange the battery for the right posts) and you should experience a world of difference. Even the slightest loose cable can result in a no start condition that you described (every accessory works but the starter only goes "click"). I can't recall how many times I've had this happen to me (i.e. loose ground cable). Good luck!
-Dean
