Originally Posted by bobcowan
Depends on the engine. FE blocks will be date stamped somewhere in the 60's; since none have been made since then. Small blocks generally will be newer, because newer blocks are easier to find in good condition.
360 FE's were put into pickups until the later 70's. My 105 "mirror" block is a 1976 block from a Ford truck. It's got the heavier main webs and thick cylinder walls. Although I'll only go .030 overbore on it, it sonic checks good to a 428 bore if I wanted.
Also, there are plenty of FE service blocks out there with no date code at all - just a blank oval pad where the date code would normally be.
