Thread: wiped cams
  #24 (permalink)
Old 02-29-2008, 08:11 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
It won't sound REAL unless the lash is .025-.029
As to the manufactures developing new profiles for flat tappet style cams--we dealt with this in late 60s early 70s when I had enough of rollers scattered thru the motor--changed to flat tappet by Howard's and working with them,developed some better grinds that moved us further in front---the limiting factor ( besides valve spring availibility ) was the edge of the lifter hooking on the cam lobe---of course NASCAR runs flat tappets to 9000+ but they oil them!!!and they use mushrume lifters with a larger diameter
