  #73 (permalink)
Old 03-01-2008, 07:07 PM
Ant Ant is offline
Default Air flow through hood scoop
Richard,
With Case 2, maybe using a large style tray semi sealed around hood scoop, with some exhaust capabilities/relief ducts off rear of tray, but I guess with the turkey pan there is a pressure build up affecting the air path? I read on Cobra Mustangs they fit a similar forward facing intake sealed system, with a relief valve exhaust that helps flow through!?!?
This seems to be a lot of work and nowadays they seem to have this problem solved by keep the air intake totally separate with eg 4" tubing and relocation of air filters in front of the radiator and you have your cold air system!
A J. Newton
The 1960's rocked!
