I seen what you mean Doug, they only list the regular one, but if you look at the pic, they show the 'Weber' style (one on the right) which is wider and a little bit taller. Maybe you can call them and see if it is still available. Might be a better choice if you are actually going with Webers to ensure you have clearance, plus it might help 'cover' where you removed the molded scoop.
