Old 01-17-2001, 12:47 PM
Chuck Hurley Chuck Hurley is offline
Post
Use 1/0 automotive type wire Power Path
#736121 by Cooper Automotive - 25' roll
Use grommets wherever you pass through the body.
Run the wire on the opposite side of the car from the fuel and brake lines and on the inside of the frame. Clamp at intervals that allow for little slack with adel clamps
which are rubber coated (available at West Marine on-line) with stainless steel construction. Tap the frame for 1/4"-20 bolts and use stainless bolts with washers under the head.
Shield the wire with black plastic flex material that is available at most automotive stores at any point where chafing or heat may be present.
Finally either use a proper swaging tool to crimp the correct size ends in place or solder them on or do both. Do not nick the wire or leave any strands outside the connector. Every little bit counts when you are running this distance.
Just use good common sense and take your time to lay it out properly.
Chuck Hurley
